Originally posted by cetane
View Post
Just to clarify a point, compression tests are also done through the injector holes.If you remove the injectors you will need to replace the sealing washers. You will probably need to remove the pipes to get access to the glowplug holes anyway. The kit I have just bought has adapters for both.
