Originally posted by 99gti
View Post
It is modern engine cooling system we talking about not a 1970 farmers tractor on its last legs.
You should also remove expansion reservoir and clean it, before you start with flushing.
I also use 70mm dia. and 500mm long clear PVC tube on adapter on the top of reservoir for easy removing of surfaced oil via vacuum extractor while the engine is running.
