Best place to buy DPF pressure sensor?
  • Best place to buy DPF pressure sensor?
    Anyone know where's the ideal place to buy a DPF pressure sensor from?
    seen a few on ebay for about $85 and apparently you can get them brand new from VW for about $112.
    Part number is apparently 076 906 051A
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    part number looks right... from memory there are 2 part numbers depending on engine code but thats the common one you have.... honestly I would just use gen VW from a dealer for a G450 sensor.... ebay will prob be a copy or faulty one..... you will need to get it adapted to the engine ECU and advise a forced regen with VCDS mate...VDUB...
    BRISBANE / GOLD COAST
