19x8 +45 and run a 225 35 19. You will not get any rubbing issues with this setup. I am running a 19x8.5 +42 with 215 35 19 with no issues and my car is salamied.
When are we going to get the new photos showing your car "salamied"?
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Thanks guys, i've been leaning towards 18's at the minute though just for the extra ride comfort... still undecided.
Have to say I was worried about this too when I was looking at 19's and chose 18's for this reason but having taken a ride in ForceFed's Golf with his 19's I didn't notice any more harsh a ride.
I was in two minds about 18s and 19s both in 8.5. I went the 19s and the problem i had was a legal one. They fitted perfectly with the standard +45 offset with no rubbing. I was running 215s which they said was a little small for the 8.5's. The problem was that the actual wheel arched out away from the tyre, which put it outside the fenders, which mean't it couldn't get a road worthy. The point of the fender is to prevent a direct collision with the wheel, which in theory stops the car from flipping in certain typed of accidents. That's why you can't get a road worthy if they are outside of that. Make sure you get the assurance of the seller that they will fit with no problems. Then you are completely safe, and can return them.
That said, i have had the past 4 or 5 months resolving problems with my wheels. I only purchased based on their assurance, which meant i could return them, but.... they sat out so i had to chase him for a refund. Not fun. Should be getting my 19s next week (IN THEORY). Exciting stuff!
Good luck! let us know how you go!
I should specify that i have a MK5 Golf. I would probably recommend that you get 8" width as well, you would get a better tyre fit. Not sure about offset but i'm pretty sure spacers are illegal.
Reason: Update
| Candy White 2007, Mk 5 Golf, 2.0 TDI | 103 kw chipped to 138 kw | 19" Mercedes C6319 Gloss Black | Stage 1 APR Cold Air Intake | DNS-810 GPS Unit (Eventually...) | Diesel Geek Short Shifter |
I was in two minds about 18s and 19s both in 8.5. They fitted perfectly with the standard +45 offset with no rubbing. the actual wheel arched out away from the tyre, which put it outside the fenders, which mean't it couldn't get a road worthy.
Well it sounds like they actually didn't fit perfectly then?
I've been looking into 19's for a while now too - consensus seems to be that to avoid any issues you'd better off getting an 8" wide rim rather than 8.5" , get an offset between +45 and +50 and the centre bore has to be 57.1mm. Recommend tyre width to avoid rubbing problems especially if lowered would be 225 but you may have issues getting the correct load rating, easier with a 235.
