Accessing oil filter on PD 2.0L
  • Accessing oil filter on PD 2.0L
    Hi All,
    If I were to change my oil filter on our BKP Passat, would I need to remove / move the EGR pipe also? I cant see the oil filter coming out through the gap.
    Stupid EGR valve and pipe ... So stupidly hard to remove.
    Bora 4Motion Sport | SAU Community
    Just remove the engine cover bracket, it squeezes out. The more you do the better you get at not making a mess, but given the filter cover has to go on an angle it can be tricky not to make a mess
      Great thanks!
      Also, not sure if you can answer this, but I read on a UK forum that people replace the bolt above the EGR pipe with a hex-headed bolt, which sounds like a much better idea. Do you know what size bolt we need for there?
