Ok I know some of you Mk1 dieselers were interested in the Govener Mod to make more power from your stock pumps... Well here it is.
A few things to do before you rip into your pump...
Thoroughly clean the out side of the pump, you don't want to have any dirt making its way inside.
If possible order a pump gasket kit so you can seal up the pump properly again. I opened mine a few times as i was playing with the amount of washers inside to get a good amount of power. And it leaked quite a bit from the o ring on the throttle shaft.
Take some pictures so you can put it all back together paying attention to the mark on top of the throttle shaft and the throttle leaver. This must be re-aligned so that your idle is not effected.
When removing the c clip to remove the Governor, place something to catch it so it doesn't fall into your pump. The first time i did this the clip fell into the pump... I was lucky enough to be able to fish it out with a magnetic screw driver... you might not be so lucky and would most likely have to remove the whole pump to get the clip out.
When driving pay attention to your red dots on your speedo... The Governor mod will allow you to rev much higher than stock and there is a potability that you could rev over 6000+ rpm. you wont be making power up here but you possibly will be able to reach these rpm...
I didn't play with the smoke screw at all and still got more power... i didn't want to make it smoke anymore than it does so i left it alone.
DO THIS MOD AT YOUR OWN RISK... There is the potential to kill your engine if you don't know the rpm you are pushing...
Enjoy
Mark
Enjoy
Mark
