Redlining a diesel
  • Redlining a diesel
    Will this hurt a diesel since it has a heavier crankshaft, rods and pistons than a petrol engine of the same size? Or will it hurt the unit injector pumps in a PD engine?
    I assume the valve gear won't care since the redline is so low.
    I sometimes redline it in 1st since the gap between 1st and 2nd is so large.
    Resident grumpy old fart
    It will protect itself from damage with the limiter.
    I don't think your the only one that redlines the TDI. I know I do.
      Not much point in redlining a Diesel since the engine is most effective at about 80% of max rpm. I remember my Astra was an absolute animal at 4,100 rpm and it had the cut-out set at 5,100 rpm.
        as long as you don't exceed the red line, i'm reckon it'll be fine. I'm sure VW tested it above and beyond.
        I give mine a good rev everynow and then, power drops off about 850-500 rpm before red, so it doesn't often see it though.
          Give it heaps (within reason) IMO, clears the turbo vanes and car runs better as well
          MY19 Polo GTi 2.0 DSG
          Previous VW cars:MY16 Polo GTI manual, 2007 Jetta 2.0 TDi manual, 2001 VW Bora V6 4-Motion - flooded away
            Like in a Petrol engine you're not really going to blow anything up - just shorten the life of the engine eventually. I'd recommend you change a little before redline though. If you look at dyno graphs you'll see that most diesels drop off heavily in power and torque near redline so there's no use going higher than 4000rpm in most cases and even with the drop in revs when you change gear you'll still be in the meat zone with an early shift because of the relatively flat torque curve of the diesels. I read an article somewhere on the net where they did 0-100 and 400m testing on shift patterns in the diesels and the one's shifting earlier before redline were dramatically faster.
            2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
              Go a few kays at 4,000 rpm in third every now and then to get the engine rid of soot. i think the "procedure" is called "the Italian clean"
                Actually, the redlining is occuring sometimes when I downshift form 2nd to 1st a bit too early.
                I never go near it on acceleration (never really get near to 90% of the red line, usually potter around 30%)
                  Yes that can harm the engine if you're exceeding the redline.
                  A rev limiter won't stop the engine from spinning over the redline on down changes.
                  Pistons will hit valves eventually depending on what revs you're seeing. Did this once on my race bike at the track, not fun...
                  MKV Golf 2.0 TDI DSG Sportline. Just nice.
                    Except the DSG wont shift down if it will result in too many revs. Maybe he has a manual though.
                    Golf GT Sport TDI
                      In that case you need to learn how to downshift. What you're saying seems almost next to impossible to do - that would mean you're shifting into first when doing about 50kmh?!?!?! Who does that? I'd image the synchro's in your gearbox would be protesting like mad!!!
                        I haven't actually exceeded it but I have run it right up to the redline on occasion.
                        I remember John Kocinski getting the boot from Suzuki deliberately lunching his (2 stroke) engine after a race when he was disappointed by it's lack of speed. They could tell by the data logging (plus you can't get a racing 2-stroke to over rev on the throttle).
                        Yep
                        Eh? I don't think there is any synchromesh on the 1st gear. I thought it only had baulk rings.
                          I rarely ever see 4k. The car is way faster if you stick to the meaty part of the rev range which in stock form is about 3500. I get out of first pretty much as quick as I can, and then torque through second. For the record, in my testing, redlining 1st gear gave me 8.5's to 100, whereas shifting quickly out of first, then at that 3500 sweet spot saw that drop to mid to high 7's. That was on Vag com, so not accurate, but relatively speaking, it was absolutely faster.
                          I know what you mean though, nothing worse than selecting a too low a gear and stopping the car with the engine! I do it from time to time, and it's certainly obvious!
                            Yeah I remember that too - John was an angry dude at times. Have heard of others doing it during a race also when not performing well! : 0
                            +1
                            With the tuning box fitted to my tdi peak torque occurs at around 2k rpm, I don't think I've ever revved it past 4000 revs lol!
                              Yeah sorry, should have said 2000-3500.
