Common Rail vs Direct Injection *Diesel*
  • Common Rail vs Direct Injection *Diesel*
    Hello all:
    Could one of you 'tech heads' please explain the diff; pros; cons; of common rail and direct injection vw diesel engines. I know only the basic stuff, but i see that some new models will have common rail.
    thanks,
    vw50
    Direct Injection and Common Rail
    Wow....This could be a long one! In a nutshell:
    • Most large truck/machinery diesels are, and some early passenger diesels were, direct injection
    • "direct injection" means just that...the diesel is atomised by the injector and sprayed directly into the combustion space offered by the ascending piston
    • direct injection diesels are generally noisier (more "diesel knock") than IDI (InDirect Injection) diesels
    • indirect injection was adopted by engine developers who saw it as a way of offering more petrol engine-like characteristics to buyers of diesel engined passenger cars and light commercials... eg less noise, smoother running and a more compact engine
    • direct injection is generally more fuel efficient than indirect injection as the fuel isn't forced to "swirl" in the pre-combustion chamber, a process that saps some of its potency
    • glow plugs to preheat the fuel in the pre combustion chamber for easier starting aren't so important in direct injection diesels (although they are still used to make the car more petrol engine-like)
    • direct injection became applicable in passenger car diesel only after computerisation of the fuel system. This combined with modifications to the pump(s) and injectors solved all of the problems of earlier direct injection engines
    Common Rail
    • until VW brought in the PD engines of the later TDIs, all diesels had a separate injection pump to provide pressurised diesel to each injector. These were either multi-element (in-line) pumps or distributor pumps like the Bosch VE used on VWs until PD was introduced
    • injection pumps are expensive and complex with very fine tolerances and are only serviceable by people who know what they're doing (having said that they are extremely durable and should outlast the engine if the fuel is kept clean and water-free)
    • common rail injection involves a high pressure fuel pump delivering extremely high pressure fuel to a pipe (the "common rail") that delivers fuel to the injectors. Unlike other systems, the fuel is under a constantly high pressure.
    • Each injector is computer controlled in order to deliver the exact amount of fuel to the cylinder at the exact time it's needed. This negates all of the "guesswork" that evolves no matter how well the fuel injecting system is designed or maintained in a mechanical system
    There's a whole lot more to this than this brief account, however it may help your understanding.
    I stand fully prepared to edit and amend any inaccuracies in the account above
    I'll move this thread to the "Diesels" forum
      well done brackie,
      vw50, you should understand that diesel technology is actually developing now, and so there are no cut and dried answers like which is better. different diesel fuel injection and combustion systems are suited to different applications, the fuel you want to use, how you want the engine to behave etc etc etc at length.
      it is interesting to note that many companies started using common rail injection before vw did, and vw are very clear about this - they feel/felt that common rail is not up to the performance and reliability standards of PD (pump duse) (someone correct my spelling).
      '98 Mk3 Cabriolet 2.0 8V
      '99 A4 Quattro 1.8T
        well done brackie,
        it is interesting to note that many companies started using common rail injection before vw did, and vw are very clear about this - they feel/felt that common rail is not up to the performance and reliability standards of PD (pump deuse) (someone correct my spelling).
        Isn't it the other way arround?
        PD system is not able to meet future emission requairments.
        Common rail is.
        VW aknowledges that and starts fitting common rail system to their engines.
        Temporarily they see window of oportunity with DPF fitted and after exhaust treatment.
        Unit injector system is not as flexible as common rail and I don't think it is more reliable either. Common rail system allows multiple injections and pre injection or after injection. Maximum pressure today is 2000 bars. Verry close to max pressure in PD system. There is less black smoke (soot) from the exhaust of the common rail than PD TDi-Before fitting DPF or after exhaust treatment.
        I've had MB Vito van which was common rail it was reliable and exhaust fumes were not as black as from VW Transporter T5 PD TDi.
        I was driving them for six years I never saw black exhaust smoke in the rear view mirror. It is not a case of VW Transporter. I can make the car behind me disapear in the clouds of black smoke if I accelerate from lights little bit faster than normall driving requaires.
        But I like driving my PD TDI's.
        Performance Tunes from $850
        Wrecking RS OCTAVIA 2 Link
          Great info
          Thanks for that info. We dieselers are always hungry for knowledge and up to date information.
          This sort of thread should really be archived so I'm going to make it a "sticky".
          What do you guys think about a FAQ page?
            Already added one (while you were away)
            EDIT Thanks for all the info guys
            - Ben
            2008 Jetta 2.0L FSI
              Originally posted by vmq6695
              Why bother? No need.
              Wikipedia does it all better (up to date, no typos, articles that are planned and therefore well structured and well written, compared to a dynamic group dialogue).
              Point your browser to:
              http://en.wikipedia.org/wiki/Common_rail (the Wikipedia version doesn't mention Lucas, so the diesel engineering teachers and textbooks I had are obviously worthless fools!)
              http://en.wikipedia.org/wiki/Pumpe-duse (hard to understand why the article doesn't mention VAG, Audi or VW; but then the manufacturer of my car, my diesel engineering teachers and texts are obviously worthless fools! Not to mention the questionability of representing u-umlaut with 'u' instead of 'ue'!)
              http://en.wikipedia.org/wiki/Turboch...rect_Injection (at last a mention of VAG - even if it refers to the 'Volkswagen Group" and not the *correct* Volkswagen Audi Gesellschaft.)
              So Wikipedia STILL does it better then........<ha ha ha> .......forgive my cynicism.
              But gee this comment hardly adds to this thread......does it? Oh well.
              Lets add something then........a new diesel injection concept with delivery pressures of 160,000psi, developed in Australia and can apparently be retrofitted. Currently seeking investment http://www.greendieselcorp.com/
              ..and the use of LPG in conjunction with diesel to make a bigger bang and reduce fuel use http://www.dieselgasaustralia.com.au/
                Wikipedia is more correct than most encylopedias but not always 100% accurate as its free for anyone to edit the pages
                VAG actually means Volkswagen Aktiengesellschaft (stock trading company )
                - Ben
                2008 Jetta 2.0L FSI
                  Or Volkswagen Audi Grupe
                    that would be Gruppe...
                    White 3-dr Polo GTI
                    Tiguan 189TSI
                      Hello, mates...
                      A yank here (Good old USA) , where we have a (very) small, but very loyal and passionate group of VW diesel owners.
                      A few comments:
                      VW developed PD as an "in-house" response to common rail...they didn't want to be saddled with 3rd party royalties, etc.
                      Actually, unit injection (PD) has been around for quite some time, and used very effectively, in most Us diesel engines, though the tide is now turning...
                      Ultimately, unit injection cannot reach the pressures of common rail, nor can it control the fuel delivery as precisely, so we are seeing a shift to common rail across the board (most diesel engines in the US are now common rail).
                      The bulk of diesels here are heavy-duty, powering large trucks or industrial equipment. Passenger cars are a very small market. Nevertheless, the transition is the same.
                        Originally posted by zanakas View Post
                        Hello, mates...
                        [...]Ultimately, unit injection cannot reach the pressures of common rail, nor can it control the fuel delivery as precisely, so we are seeing a shift to common rail across the board (most diesel engines in the US are now common rail).
                        Bosch passenger common rail system 3rd gen piezo injectors 1800bar.
                        Invented for life: we want our products to spark enthusiasm, improve quality of life, and help conserve natural resources.
                        Bosch passenger unit injector system type UIS P2 exceeds 2500 bar.
                        So the advantages of common rail is not pressure. Bosch even describes higher pressure being achievable with unit injectors:
                        "The UIS does away with high-pressure lines and thus enables injection pressures in excess of 2200 bar on passenger cars."
                        Common rail systems require numerous high pressure connections and consistent high pressure. Unit injectors presumably generate intermittent high pressure running off the camshaft and one connection per injector unit requiring the high pressure seal.
                        Common rail has other advantages presently, but it seems fairly likely the engineering challenges will be met with unit injector systems over time and cost of unit injector systems is likely to be lower over time due to scale economies in manufacturing.
                        Unit injectors have the clear advantage of redundancy improving reliability. A common rail pressure failure will bring the engine down. A unit injector pressure failure will bring one cylinder down.
                        Certainly I was impressed by the lack of usual diesel engine noise in the common rail Tiguan diesel.
                        2015 Polo Comfortline 6M + Driving Comfort Package
                        2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
                        (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
                          My understanding is that they changed because VAG Common Rail engines can be tuned to produce less pollution than their PD engines.
                          This is because CR allows more injection events per combustion cycle than is practical for PD. Having more injection events gives more precise control over what happens during combustion, thus producing less undesirable gases (NOx ?).
                          I have read reports that the VAG CR 4 cyl engines are much smoother and quieter than their PD equivalents. Of course some of this can probably be attributed to being a more modern design.
                          IIRC there's not much in it for fuel economy, and the PD is said to produce more torque at low revs.
                          Basically there's not much you can do about it if you want a PD motor except buy now before they change over, because in the future they will all be CR whether you like it or not.
                            I was suggesting that any particular performance/noise differences between those two diesel injection technologies may be due to present performance of present products and not necessarily a fundamental constraint of the technology which could be improved by further research and development.
                              A bit lateral to the thread topic (and perhaps best moved elsewhere...)
                              I understand Volkswagen itself uses:
                              * Volkswagen AG, AG being the German equivalent for Australian Pty Ltd.
                              * Volkswagen Group, which holds Audi, Seat, Skoda, Bentley, Lamborghini, Bugatti, Scania and other miscellaneous related companies.
                              "You can download a full list of the holdings of Volkswagen AG and the Volkswagen Group from this page."
                              Volkswagen Audi Group (VAG) apparently dates to 1978-1992.
                              The website uses VWAG rather than VAG. Ticker symbol is VOW. Present information suggests VAG is a historical abbreviation no longer used by Volkswagen or the Volkswagen Group.
