G-8VXWWTRHPN Exhaust warning light on, - VWWatercooled Australia
    They can use 2 or more different part no. but so much for the part numbers written on the components.
    You can ruin the DPF.
      Originally posted by Cupra View Post
      Hi all
      My wife was driving the golf (05 2.0tdi) today when the exhaust warning lamp came on with the exhaust workshop warning in the mfd. The car seems to drive fine with no change in the performance, the light is still on after the car had cooled down ( I ran it when I got home. The book says to take it to the dealer, any advice?
      & yes I have done a search & couldn't find anything relevant.
      cheers
      Phil
      Why wouldn"t you follow the precise and indeed clear intructions ias detailed in the "book".....
        More info
        Have now been told there are two valves in the system. One belt driven and one electrically operated.
        Both are required. Apparently it I the belt driven valve that has failed in our case.
        Asking further as to what is the function of the valve... via Chinese whispers... Tech to service desk to me... it allows water to circulate and cool exhaust gases.
        So new to diesels that my knowledge base is apalling but looks like I will be learning fast.
        You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
          I was simply looking for any advice from the wealth of knowledge on this forum before talking to the dealer. Sorry to hear of your dramas Highlander, we had our golf home the next day, just the overnight stay at vw.
          Phil
          Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
          2012 BMW X3 MSport 2.0D
            Ahhh, OK, it's the water cooling of the exhaust gas that has failed Highlander, so basically the car is getting hotter than normal exhaust gas, car will be down on power, that's all, economy will suffer a bit as a result. I agree it wouldn't be too harmful, but it's odd the 103 flap is belt driven, the one on the 125 is electronic, but it is a totally different system.
            What model / year is the car mate, I don't know of anything sub MK6 in 103kw that had a DPF..... and extra exhaust gas, or hotter than normal, or lack thereof due to a faulty EGR valve won't hurt the DPF, would help keep temps up if anything else and burn off a bit more carbon! The health of the turbo, well that's a different story..... but not a problem in your case Highlander.
            Sounds like a mob of chimps run your local dealer mate....
              Well I got mixed that one up, really. I thought that Highlander is talking about Passat 125kW TDI with the DPF and referring to DPF light on the dash.
              Sorry, to confuse you guys.
                No perceptible drop in performance.
                April 2009 build Mk VI Golf TDI 103. Certainly not down on power either. Sales Manager at dealers (who I can't speak more highly of) usually drops me back at work and then delivers the car to me after service commented on how strong this car feels in comparison to other 103 TDI Golfs. Maybe it's the 30000 kms but seat of the pants the torque, acceleration etc is great and hasn't seemed to have suffered with the exhaust gas problems. Never measured but if feels quicker than my CC 125 TDI Diesel.
                Probably isn't in reality Golf 13.39 kg/KW. CC is 12.2 kg/KW.
                Note I said the Salesperson who helps out. Too hard for the service guys to spend three minutes dropping me back to work. Customer Service is always too busy.
                  Exhaust Gas Warning LAMP - Repaired
                  Car was repaired today. Invoice (Warranty) states "Replaced auxiliary coolant pump".
                  As the car has just over 29,000 km decided to do the 30000 km service at the same time and also requested throttle body clean.
                  Imagine my surprise when the total invoice cost was $74.00. Here I am thinking VW service was suddenly very reasonable. Not so. They had overlooked doing the 30000 km service. Service Desk had forgotten to put it on the Job Sheet.
                  They offered to do it there and then but as it was already 4.10 pm, I didn't fancy the idea of the 30000 km service being rushed through by 5.00 pm.
                  Oh well, what is another day without the car. Sometimes I'm glad we didn't accept the low trade in figure for our 230,000 km Corolla. Sort of like having our own loan car.
                    I'm guessing this is M.V. Volkswagen service dept. you're referring to ? I used to have to take mine to S.C.C. VW in Wollongong and the service dept. there also leaves a lot to be desired.
                    Russ
                    2005 Subaru Outback 3.0 R Premium
                      No names, no pack drill but where do you have yours serviced now>.
                        We have a newly opened VW dealership on the South Coast (Nowra) So far so good
                        Russ
                        • #27
                          Besides kicking up a fuss on a message forum, have you considered sitting down and having a chat with those in charge at the dealership?
                          Seems like the logical thing to do if it's improvements in customer service you're after.
                          • #28
                            I think that Highlander has every right to be upset.
                            • #29
                              No doubt about it.
                              • #30
                                If only it was that easy
                                Tried that logical approach already without much success. Not sure if anyone is really in charge, much less in control.
                                I am a very slow learner but not as slow as some customers service departments. To date I have not had a service that has been totally satisfactory or that have not required taking the car(s) back again for something. Or something as silly as taking 25 minutes to find the keys to my car after arriving at the dealership to pick up the "serviced" car. Service Desk had rung 45 minutes earlier to say the car was ready.
                                To be good at customer service you need to enjoy customer service plus have good communication and trust between the guys on the tools and the guys on the desk.
                                If I have a customer that has a justifiable gripe, we make sure that next time we see them they are VERY well looked after. We may go as far as marking their file "We stuffed up this customer last time. Make sure it doesn't happen again. Doesn't seem to happen that way in the car game.
                                Dealer service is not cheap in price so there is no reason for it to be cheap in quality. And it is the "Management" that either makes or breaks a service facility.
                                Previously after numerous complaints about a leaking hardcover on a ute, the comment "You could use it as a goldfish pond" was not really appreciated. This came from a senior manager at the dealership who seems to have failed in his first choice career as a comedian.
                                And I still take two vehicles there for service. As I said, I am a slow learner.
