So i've got a MK5 TDI 2.0L, recently had the turbo replaced (and manifold and actuator, etc, thank god for dealer warranty!), but after playing with Vagcom i've noticed that is quite obviously overboosting.
I had the Bluefin (superchips) map on it and the 'specified' boost matches the actual on soft acceleration, but full throttle from 1500-4000rpm in 3rd it goes beyond what Vagcom will measure. Ambient pressure was .989bar, boost specified was 2.5bar (this includes ambient) and actual was well above 2.6bar, while this doesn't sound like a big difference, it shouldn't be going beyond what the specified is, I believe...
What I want to do is test some things, like the MAF to see if anything is going bad and causing this issue. I do notice at idle (it's a manual) occasionally it feels like it may miss a beat. There's no error codes or anything from the ECU and on the stock map (what its on now) it seems to perform OK.
How do I test the MAF? Are there any other things I should test for? It also has a new EGR!
I don't know how to attach an excel spreadsheet here, but I can list out the data from a flat out 3rd gear run:
(Edit - Pasting it in and reformatting wasn't working, so simply take these values in the column and paste them beside each other into excel, will make a lot more sense then....)
TIME
STAMP
7.8
8.28
8.77
9.25
9.72
10.21
10.69
11.18
11.68
12.18
12.66
13.14
13.63
14.11
14.61
15.08
Group 9 - Field 0
Engine Speed - (G2
/min
1848
1848
1995
2184
2394
2625
2835
3045
3276
3465
3654
3801
3948
3885
3675
3213
Group 10 - Field 1
Atmospheric - Pressure
mbar
989.4
Group 10 - Field 2
Boost Pressure - (actual)
mbar
1611.6
1346.4
1642.2
2101.2
2601
2601
2590.8
2601
2601
2560.2
2478.6
2407.2
2335.8
2264.4
1713.6
1397.4
Group 11 - Field 1
Boost Pressure - (specified)
mbar
1040.4
2397
2468.4
2529.6
2529.6
2529.6
2499
2468.4
2448
2417.4
2386.8
2346
2295
1071
1060.8
1040.4
Group 11 - Field 3
Charge Pressure - Control Duty Cycle
70.9
74.1
68.5
45.4
25.1
38.3
33.1
28.7
25.5
23.9
22.7
19.9
17.5
44.2
44.6
46.6
Any analysis?
Thanks,
Aaron
TIME
STAMP
7.8
8.28
8.77
9.25
9.72
10.21
10.69
11.18
11.68
12.18
12.66
13.14
13.63
14.11
14.61
15.08
Group 9 - Field 0
Engine Speed - (G2
/min
1848
1848
1995
2184
2394
2625
2835
3045
3276
3465
3654
3801
3948
3885
3675
3213
Group 10 - Field 1
mbar
989.4
Group 10 - Field 2
mbar
1611.6
1346.4
1642.2
2101.2
2601
2601
2590.8
2601
2601
2560.2
2478.6
2407.2
2335.8
2264.4
1713.6
1397.4
Group 11 - Field 1
mbar
1040.4
2397
2468.4
2529.6
2529.6
2529.6
2499
2468.4
2448
2417.4
2386.8
2346
2295
1071
1060.8
1040.4
Group 11 - Field 3
70.9
74.1
68.5
45.4
25.1
38.3
33.1
28.7
25.5
23.9
22.7
19.9
17.5
44.2
44.6
46.6
Any analysis?
Thanks,
Aaron
