supercharging a 1.5 diesel???
  • #16
    hey mate,
    the pistons are probably 1.6 ones - they have a 1mm larger wrinst pin as i recall and different height (1.6 uses a longer stroke, same bore).
    btw - the depressions in the piston crown are actaully part of the combustion chamber.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    • #17
      yes . . . and NO.
      well, the gudgeon pin is smaller on the new ones i bought , by about a mm or 2 , havent even bothered measuring the damm things! !
      and the distance from the crown to the gudgeon pin is around 4mm greater, meaning that the piston protrudes 4mm or so more out the top of the block . ! !
      im assuming someone made a mistake in the parts bin , and has labeled them wrong !
      doesnt help me with this 1500 motor either way. !
