Hi Guys,
My 05 Mkv TDI has now done 106000km. I'm doing around 26000km per annum and have had the car for just over 2 years. She's developed a clunking sound when she first fires up (clutch in or out) and also when you first set off under acceleration (2-3 clunks) and under engine braking.
I've had her inspected thoroughly twice by the same mechanic, once when it first started and again last week (as it has worsened considerably). In both instances we haven't yet been able to locate the source of the noise and vibration.
Things that we've discounted are;
CV Joints
Gearbox mountings
Engine mountings
Suspension bushes
Front main drive pulley
All seem to check out ok.
As the clunk often occurs on start up, under acceleration and engine braking we're now thinking it might be something to do with the dual mass flywheel. My mechanic has removed the starter motor to gain access to the DMF and noticed that there is 6-7cm of play between the front plate of the DMF and the rear
this means that whilst the rear plate remains fixed to the motor the front plate will rotate 6-7cm before taking up this slack and locking up with the rear plate. My internet research has revealed that the amount of play should be 0-1cm! I also learnt that DMF's are considered a weak point on Golfs (particularly 2005-2007 models) and there have been many instances world wide of DMF failure in both manuals and DSG's often resulting in holes through bell housings, DSG's and in at least one instance the DMF seized the DSG which in turn caused significant damage to the engine. In these instances both the engine and DSG had to be replaced.
There has been much talk of recalls including one on TDIclub.com referring to the 'Australian recall'.
Does anyone here know of an Aussie recall for Golf dual mass flywheels?
Also does anyone with mechanical knowledge of such things think that 6-7cm of rotational play between the front and rear plates of the DMF acceptable?
Any information would be much appreciated.
CV Joints
Gearbox mountings
Engine mountings
Suspension bushes
this means that whilst the rear plate remains fixed to the motor the front plate will rotate 6-7cm before taking up this slack and locking up with the rear plate. My internet research has revealed that the amount of play should be 0-1cm! I also learnt that DMF's are considered a weak point on Golfs (particularly 2005-2007 models) and there have been many instances world wide of DMF failure in both manuals and DSG's often resulting in holes through bell housings, DSG's and in at least one instance the DMF seized the DSG which in turn caused significant damage to the engine. In these instances both the engine and DSG had to be replaced.There has been much talk of recalls including one on TDIclub.com referring to the 'Australian recall'.
