INDEX of the useful informations that you just want to post a question about. Look down, maybe it was already answered.
Stickies
Additives
Air intake
Exhaust
Turbocharger
Fuel Injection
Fluids and Lubricants
VCDS (VAG-COM)
Common Faults
Stickies
- http://www.vwwatercooled.org.au/f28/...ine-12575.html
- http://www.vwwatercooled.org.au/f28/...-faq-6114.html
- http://www.vwwatercooled.org.au/f28/...sel-31515.html
- http://www.vwwatercooled.org.au/f28/...ugs-46122.html
- http://www.vwwatercooled.org.au/f28/...est-12233.html
- Adding switches to the blank switch covers.
- http://www.vwwatercooled.org.au/f28/...gin-13929.html
- http://www.vwwatercooled.org.au/f28/...nue-28464.html
- Brakes Front brake hoses for TDI
- http://www.vwwatercooled.org.au/f28/...els-27696.html
Additives
Air intake
- Catch can
- DID IT! sprayed a can of throttle body/ carby cleaner into the egr/manifold......
- Caddy TDI inlet clean
- EGR Provent Install 2.0L TDI PD
- Intercooling
- DIY FMIC for mk3
Exhaust
- DPF regeneration
- http://www.vwwatercooled.org.au/f28/...ion-48738.html
- A potential delete option for the DPF
- Exhaust exhaust and turbo discussion
- Excessive smoke Jetta TDI
- EGR Valve and Inlet Manifold CleaningLet the tinkering continue.....
Turbocharger
- Stock boost level for 1.9TDI
- http://www.vwwatercooled.org.au/f28/...uge-42575.html
- Variable Turbocharger
- Turbo upgrade for TDI
- Tuning
- Cleaning VNT turbocharger
- Exhaust Flow Calculation
- Pyrometer install/problem.
Fuel Injection
- Diesel/LPG conversion
- History of Common Rail diesel injection
- 2GO kit for using biodiesel in Golf5 TDI
- Biodiesel B20 and B100
- Fuel related questions LPG & Nitrogen
- Diesel LPG injection
- Hydrogen injetion
- Diesel + LPG or Hydrogen?
- DMF Dual Mass Flywheel
- Fuel filter 2.5 TDI
- High pressure fuel pump problems
- Engine oil questions 1.9TDI and 2.0TDI common faults
- http://www.vwwatercooled.org.au/f77/...out-45648.html
- Oil change D.I.Y. GOLF5 2.0L TDI
- Oil temperature fitting gauge
- Oil consumption 2.0LTDI
- Golf GT Sport TDI Data thread
VCDS (VAG-COM)
Common Faults
