Oil !!!!!
  • Oil !!!!!
    The oil consumption on my new tdi_eg is a bit stunning.
    Checked the oil for the first time yesterday.. at 759km it is already below the add mark... yikes.
    Put half the supplied bottle in until I get some more .. but it really needed the whole litre.
    Now I know why they supply oil... but at this rate I need to buy it in 20 l drums
    This is almost 2 stroke territory .. about 1 :100..
    I certainly haven't been babying it ....or thrashing it either.
    Just love the car but I'm not telling any of my Tonka loving friends about this dirty little secret ..
    dont worry, it wont last.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
      I'd be talking to the dealer sooner rather than later. They will likely put you on their "oil consumption" watch where the oil level is carefully monitored, and they record all top-ups amounts accurately. Some VW engines use oil, some don't, but the odd one uses altogether too much.
      Just out of curiosity, how have you been driving it so far (length of time idling, usage of cruise control, any special running-in regime) ?
        At BEST your oiler will take several thousand kms to run in. I've heard people mention 10 - 40 k for a full run in!
        Mine used a bit of oil in the first few thousand, but there's been stuff all since. Don't baby it, use the boost!
          like said it should only your oil for the first couple of thousand km,s
          & dont be alarmed by it as it is perfectly natural
          (]/_ O _____ O _\[)
          "'(O8o)=\X/=(o8O)
          [__|========|__]
            thanks
            Thanks for the info, as I said I love the car
            I will keep a close eye on it.
              My oil warning light came on a few weeks ago just as I was driving out the drive at 2130 to head to work! WTF! Anyway put in back in the garage and took the Jag instead.
              Called the dealer service guys and they said didn't you get told when you picked it up it would use a lot of oil in the first year. Um no I didn't get told that.
              Anyway they told me what oil to get so I just topped it up next day. No oil was included with my Golf. I'm now checking it every few weeks
                tick....in fact a bl*** big tick ....
                So , I was heading south to do some stuff , so called in to Southside VW (Pacific Hwy service road Brisbane)..
                (Me) Hi ...can I buy some oil.
                (them)No sorry .. you need to go to the spare parts division .. but we can fill up your bottle.
                (me) .. uhh left it out with the tow bar stuff.. uh is this consumption normal??
                (them) nope thats a bit excessive.. is it full up now ??
                (me).. no .. I only half filled it 'cos didn't want to run out of oil
                (them) .. can we check it and top it up ???
                (me).. a bit taken back.. oh sure .. gee thanks..
                (them) ((operative take treg away and comes back))..oil is ok
                (me) oh .. heh heh ...must have warmed up and xpanded a bit
                (them).. yep .. the level moves a fair bit cold >hot.. but we want to know if it keeps using oil .. and we will give you oil .. just bring in the bottle..
                (me) .. thinks driving out.. this was fantastic service....
                Southside vw Brisbane ... big tick .......
                  Similar to tgh, I called in at the local dealer when the light came on they filled and I was on my way. They did this twice in the 1st 15k all at no charge and then when I had the 15k service they (Penrith VW) gave me a litre for topping up which was only needed in the 30 to 45k service interval.
                  SPoddy
                  2020 Tiguan 162TSI R-Line
                    I wouldn't be too concerned about it.
                    Just take Greg's advice and give it hell straight away (low Kms, not freezing cold..). You need the boost to help the rings seal and intern, help them bed in. Driving it conservatively is actually worse for it.
                      dont glaze the bores
                      get into it within reason, diesels like a 60% workload or better, if you don't you could glaze the bores.
                      Spark ignition is a threatened species
                      Biodiesel is the best emission control money cant buy
                      MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
                        I nearly fainted but now I understand - I think.
                        A few weeks ago when the warning light came on I went to supplying dealer in Townsville. The mechanic gave me a litre in my (dry) water bottle. No charge! For Townsville (rip-off city) this was incredible.
                        When my Mk V was due the 15K oil change I was asked $380. For < 5L oil, filter and, presumably, an hour's work. Was this to repay them for free oil top-ups?
                        Castrol wanted nearly $380 for a 20L drum of VW 507 so I looked around and found 20L Mobil VW 507 (IE. Mobil 1 ESP 5W30) for $239. Nobody seems to do 5L.
                        I'm following the illustrated instructions at www.myturbodiesel.com
                        I just wrenched off the engine cover and took out the filter. It's a Purflux L267A with VW and Audi logos. "Made in France" I could not find a large O ring as described though. I wonder if they are no longer used - anybody know?
                        Also, anybody know where to source this filter - or equivalent?
                          I found that the dealer is cheapest, some aftermarket oil filters aren't made the same way as original Purflux (nice filter).
                          Performance Tunes from $850
                          Wrecking RS OCTAVIA 2 Link
                            My 15K service cost $528 and only $76.73 was for the oil.
                            Most of it was labourI was amazed at how all the little (except the labour) things add up.
                            BTW my TDI didn't come with any oil and, like a girl, I never think to check the level
                              My dealer (Essendon Volkswagen) offer a top up service. You just bring the car in and they check the oil and windscreen washer levels.
                              So far so good, I haven't had any dramas. Oil use has been negligible. I'm going to take it back again at 22500km.
