Originally posted by ST33VI
View Post
1 of 2
2 of 2
My Golf GT TDI Catch Can + Intake
....because Scotty, that oil is covering everything from just after the MAF where it re-enters the intake, to the intercooler, pressure sensors, EGR, flap, and THEN clogs up the difficult to clean swirl flaps and inlet ports. This is the black plastic part that is right before the head, and removal of it, and cleaning out the head ports as well is the only way to do it properly.
A lot less difficult to get a can / Provent / whatever, and plumb the outlet high up in the exhaust. There's always the spray clean option, but given I have a DPF, that's out of the question. Different for you guys.
Explain to me WHY making your ports smaller with a goop coating is a good idea, when most of us are after MORE power???2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
.... put a water spray on your SMIC too Scotty, even a crude one ala Polar makes a big difference.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Great product to get the crap out of the engine is Subaru Upper Engine Cleaner
Buy a few cans... Use them every time you feel like your car is clogged up.
At subaru they call it the "Service in a can"
I put it in my 1.4 and when you start up you get white smoke for like 2 mins.
Next time I did it was only 30 seconds or so- Much cleaner.*Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
Economy at 100kph =5.5L
You forget we run compression ignition mate. Put anything into the inlet tract that can combust, and well you're basically flooring the throttle. Remember that a diesel is throttled by fuel, and not air fuel mix like a gasser. It's basically WOT all the time air wise.
If it's something you mix with the fuel, well it's all well and good, but it doesn't clean the inlet tract where our problem lies.
Provent, Provent, Provent, or a similar decent catch system. Or get rid of your oiler at 100k.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
You don't need a provent.
Just whack some hose going underneath the car and man up and whack 1L of oil as needed.
I would rather have to top up my oil and thereby get fresher oil, than have all my old ail religiously collected and put back in sump.*Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
Originally posted by mikinoz View PostI'm down with that. Even better I may jam it into an old drink bottle so I can measure it.
What do I do where the line would normally return?
If you look at car magazines for hardcore drag cars... check out how many oldschool cars are just running the hose to ground technique.*Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
...fine for the odd 400m run, but a bit irresponsible for a daily drive given the easily added options out there.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
.... and if it drips oil onto the road it is definitely not nice at all (add water = road with very little traction, particularly dangerous for bikes)2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
if you block it off, the crankcase will pressurise and blow out hte oil seals.... gee that'd be nice wouldnt it.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Originally posted by gldgti View Postlucky you have your disclaimer in your sig....
You would block that off as your breathers are now going elsewhere.
As far as bike are concerned I am tired of carrying them by paying more for my third party insurance than I should. If each bike owner paid their share compared to the cost they cause they would be paying $15,000 a year or something compared to $400.*Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
Originally posted by mikinoz View PostWho was the best supplier of Pro-vent in Sydney again? I have used ANOTHER litre of oil between services now.'07 Touareg V6 TDI with air suspension
'99 A4 Quattro 1.8T
