HELP!!! I am chasing two front brake hoses for my 1996 Tdi, and I am being quoted between $80 and $120 per side!! Ouch. I am told that the fittings on the end are unusual, but they are the same as the hoses from a VR6 (vented rotors) even though the Tdi has solid. Anyone got any ideas where to go for what I would have thought to be a fairly standard part? Maybe the UK? any ideas welcome the brakes are a bit spongy! Can anyone tell me the correct OE part number, that will help the internet search. Cheers
1 of 2
2 of 2
Front brake hoses for Tdi
Originally posted by sparkie View PostHELP!!! I am chasing two front brake hoses for my 1996 Tdi, and I am being quoted between $80 and $120 per side!! Ouch. I am told that the fittings on the end are unusual, but they are the same as the hoses from a VR6 (vented rotors) even though the Tdi has solid. Anyone got any ideas where to go for what I would have thought to be a fairly standard part? Maybe the UK? any ideas welcome the brakes are a bit spongy! Can anyone tell me the correct OE part number, that will help the internet search. Cheers
[Edit] As above, if you're in no rush, might be best to import a set.GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
call around all the vw parts places... Tooley imports, HSY, etc etc. even so, i wouldbe ne surprised if you have to pay $80 a side anyway.
on another note, why do you think you need to change them? are they physically damaged? spongy brakes can be caused by many things...1st culprit is usually air in the lines, or old fluid that has absorbed some water.
mk3 brake system with ABS is suggested to be full system bled every 2 years.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
The inner lining has broken and the outer lining is bulging on one set, and there are cracks in the other set. I got quoted $118 per side from Northern Volks via VW themselves, no after market, and $85 from my local parts guys (Northenr Volks guy says go for the $85 ones because they are probably wrong. ABS have quoted $45 per side custom made possibly using the male part off the old ones. In the UK these are under ten pounds!! The part number is peculiar to the Tdi and whatever that 6 cylinder thing is called, and not the same (I am told) as the petrol Mk3s. Thanks for the suggestion to renew the brake fluid I'll get that done as soon as.Mk3 Golf Tdi about to sell
Mk 1 Golf GLD somewhere in a paddock!
Mk1 Golf Cabriolet
MK2 Golf Turbo diesel engine and 5 sp gearbox
If it is going to be that expensive for std hoses I'd check out how much it would cost for custom made SS braided hoses (less flex).2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
Test Slow
