Are there any problems with using copper for fuel lines?
I think the easiest way to upgrade the fuel lines in my car are to braze a new 1/2" copper pipe in place of the old petrol return fuel line in the plug that holds the sender (in the side of the tank). Run the current large fuel line as the return line for the diesel.
For anyone who doesn't know, the tank sender is welded to the current fuel line, so changing the size of that would be problematic, but if i replace the small return line, everything should be fine.
Using nice big 1\2" copper lines will ensure i get good fuel feed even on cold mornings when my biodiesel is thicker than usual!
