I recently put new vented rotors, calipers etc onto my Mk1 GLD. This was not quite a bolt-on job, but in the end got it all fitted. I have also replaced the master cylinder and the rear slaves. My vacum pump seems to be OK, booster is original.
The brakes are now very effective, but the pedal is well down, and does not feel right. When the engine is off, the pedal is quite firm, but with the engine on, the pedal softens and drops appreciably. The brakes, in use, are not "instant" rather you have to make the pedal travel before the brakes bite.
One thought I had was that the new calipers require a greater volume of fluid to activate them, but then doing my own brakes taught me a lot about what I don't know, so I would appreciate a few lines of advice.
Hendo
Hendo
