Will 1980 Passat Engine fit in 1979 Golf GLD??
  • Will 1980 Passat Engine fit in 1979 Golf GLD??
    Hi All,
    Looks like I need a new (secondhand) injector pump for my Golf GLD.
    Saw there is a 1980 Diesel Passat on eBay with good engine/injector pump - just wondered if the engine would fit in the Golf?? Obviously the gearbox will be no good to me, but are all the engine mount threaded holes the same??
    I thought I could maybe swap the entire engine and keep my original motor as a spare. Has anyone done this before??
    Any thoughts?
    Thanks,
    Huw
    Yes
    I personally haven't done a swap/replacement but the Golf/Passat blocks are identical.
      You may have to drill the lower engine mtg holes out?
        i think its identical - sump is different shape, htats about it
        '98 Mk3 Cabriolet 2.0 8V
        '99 A4 Quattro 1.8T
          I think its the same. shame to pull apart a diesel passat tho.
            On some of the Passat motors the rear or manifold side lower bell housing bolt hole was threaded for a bolt. Being a later motor it might be ok. Check first or else you ain't going to get the gearbox stud through there!!!
              Thanks again!
              Thanks guys,
              Brilliant response once again.
              I have another question - see my latest post!
              Huw
