G-8VXWWTRHPN Misfuelling - prevention - VWWatercooled Australia
  • Misfuelling - prevention
    Not that this has happened to me or my family ever, but the prospects of someone misfuelling a diesel in a petrol world seem very real and possibly very expensive.
    The RACQ is reported as having run a recent story on misfuelling.
    ...at the end of the article is an ad for a misfuel prevention gadget that seems a bit steeply priced @ 66euros.
    Anyone know if the solodiesel gadget will work with our bowser nozzles....
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
    Doesn't surprise me... My mother just destroyed the engine on her beloved passat after ignoring the engine temp gauge was on max, continued to drive for 10 minutes as she couldn't be inconvenienced to pull over and check what was wrong. Now the car needs a 4k rebuild, the cylinder head and the entire cooling system are both destroyed
    There are incredibly stupid people everywhere, even your own flesh and blood unfortunately.
    Thank god she'll never drive any of my cars
      '98 Mk3 Cabriolet 2.0 8V
      '99 A4 Quattro 1.8T
        http://www.youtube.com/watch?v=arfNofxBtfY
          Clever. I think it could work here, but I'd wait to see if something similar is introduced here first.
          I filled up my car today for th first time and I checked and rechecked to make sure I was filling up with diesel. A pleasant change not having to wait in line to fill up at a petrol pump and also, the diesel pump flows much faster. Filling is over in a few seconds!!
            Yes, we pay more for that privilege.
            Performance Tunes from $850
            Wrecking RS OCTAVIA 2 Link
              Wait till you pick a truck sized diesel pump nozzle, THAT takes a while!
                Only if you have a skinny VAG filler pipe - on my Landcruiser it was scary watching the $ figure increase when filling up from near empty - those pumps can really push the diesel in fast !
                I still remember the counter jockey at a Mobil station at Hay abusing me for "having a stupid european diesel with the wrong size filler pipe" when I politely suggested that they need to get some smaller nozzles (after I had spent 10 minutes dribbling about 30 litres into my Transporter). On principle I will never, ever buy fuel there again.
                  Elaflex makes:
                  ZVA slimline
                  ZVA 25 hi flow to 140L/min (OD 31mm)
                  ZVA 32 hi flow to 200L/min (OD 39mm)
                  Gilbarco lists three flow rates on standard bowsers:
                  Standard flow 50 litres/min - presumably slimline
                  Hi-Flow Diesel 80 litres/min - presumably 25mmID/31mm OD
                  Ultra Hi-Flow Diesel 130 litres/min - which could work with 25mm nozzle
                  Both skinny and fat nozzles at the local BP fit right in Polo filler neck. Is there a third size at truck stops???
                  Do you have a skinny filler neck like this:
                  image deleted
                  pic on this page
                  Check this if you need a portable adaptor...http://forums.tdiclub.com/showthread...=113333&page=5
                  image deleted (on page above)
                    Bluey those images dont show for non-members of tdiclub.
                    bp summer hill has a skinny & large nozzles for diesel. the large doesnt quite fit in my mk5 filler pipe. Had to dribble it in - was very annoying.
                    MY08 2.0L TDI DSG
                      B#@@er. Worth joining if needed to see the pics. Costs nothing. Loads of good stuff there.
                      The first picture shows a filler neck restricted by plastic and several plastic ribs that looks small enough to only permit a ULP type slim filler nozzle. Is that what people here have in some models here??? Apparently in the USA, it is for cars designed to run on ultra low sulphur diesel to maintain emissions compliance. 31mm OD nozzle fits fine in my Polo.
                      The second picture shows an adapter made from copper plumbing reducers and pipe soldered together small enough to tuck into the space inside a large fuel flap. That pic is in the thread mentioned. Someone built one including home-made O-ring from flexible tube to seal with the fuel nozzle to prevent splashback.
