spacer question
  • spacer question
    Hey Guys,
    If i'm running stock wheels with H&R lowering kit on the roc what is a good size bolt on spacer to go to sit nicely on a daily ride?
    I tried searching the forums and couldn't find the answers to what i needed
    D
    Personal opinion on what fits nicely and what doesnt. Throw a tape measure on the wheel and see how much you would like it to come out. 5mm = 5mm spacer.
    Keep in mind they are illegal in OZ. Make sure you get a decent quality one with correct specs and botls
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      If you want to stay legal then get a new set of wheels with the correct offset.
      - Tigger73's 125TSI Build
        legal or not - i actually like the stock wheels with a lowering kit i just want to fill the guards a bit more.
          Yeah I wasn't saying anything about not liking the stock wheels. You just need to get a wheel (OEM or not) with a different offset
          If you want to fill out the guards you need to go to some thing like 18 or 19x8 ET35.
            I ran a 12.5mm on the stock wheels without any problems with the H&R kit, and I've seen 15mm on the same. 15mm is probably as far as you'd want to go before you get undue attention.
            Running now 12.5mm spacer on 19x8.5 ET45 (so that's equivalent of nearly ET33).
              Hey DVSTwig, did you use your stock bolts?
              2012 VW Scirocco R 2.0L TSI - Candy White
                With a spacer anything more than say 5mm you really should use new extended bolts...
                Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
                Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
                  Agreed, I used extended bolts. I even purchased another four VW plastic caps so that I you didn't see them. 1 of the 4 stock caps is to fit the lock nut, and wont fit the extended nuts.
                  EDIT:
                  This is the set I'm using
                    I reckon you can come out 15-20mm to sit flush. Not sure if you want to actually go that far with a spacer tho
                      Haha.. I had 24mm spacers on the front... I am in the process of reversing the centres on the BBS LM's which changes the off-set by 16mm so I will be back down to 9mm (custom) spacers to clear the Brembos.
                      Realistically if you are going that sort of size on spacers you need to look at the ones that bolt onto the disc / hub and have studs... much less load on the wheel bolts.
                        OK so im running 19x8.5 et35 and 245 tyres.
                        I want to max out the width - anyone want to cross verify 5mm be fine?
                        I think i need my rear re-aligned too - my driver side sticks out 5mm, passenger side inset 5mm ....
                          I wouldnt bother with 5mm spacers...you really cant get hub centric spacers for 5mm and you run the risk of vibration at speed if the rims are not properly centred... dont expect the wheel nuts to centre the rim...
                          As for the rear... Umm I would have it looked at because there is no way it should be like that...
