Launch Control - Flashing?
  • Launch Control - Flashing?
    Hi All,
    So I tried to L.C. a couple of times and it just seems it does not exist on the car. It is in the manual and I have followed the steps with no luck.
    I notice that if the brakes are on (I held the lightly, enough that they are engaged) and I rev the car, the car starts to creep forward.
    I did find one note on the web, if you cannot REV past 1200 RPM LC is not enabled in the car.
    Is that the case with the AUS cars? Or it should be there since it is in the manual?
    Thanks,
    MJ
    Launch control definitely works, you have to be in sport mode, foot on brake, disable traction control by pressing and holding the button for 3 secs, then while foot still firmly on the brake pedal you floor the throttle, revs will sit at 3k then release brake drive away.
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
      And be prepared for it to be violent...
      Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
      Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
        It's the same system as on the Golfs. Occasionally I've noticed it can get confused, especially if you creep more than a few metres whilst in M or S, even with the T/C turned off - the launch control can disable itself and applying the throttle will engage 1st and start releasing the clutch. If you find that happens, stop the car, push the selector back to D, and then back to M or S, and launch control should be good to go.
          I also found out today that with TC completely turned off the Rocco has a new auto function in the wet.... Auto lane change under WOT
          Best not to try LC on a wet road methinks
            AWD didn't come to the rescue?
            Audi A3
              Well done Andy
              The Scirocco doesn't have AWD.
              Which takes a little adapting, especially for those of us who came from previous Quattro / 4Motion vehicles :/
              MY12 Scirocco R - slightly not stock :rolleyes:
                There is a certain charm to wheelspin well into third gear...
                  Oh really, I thought all R line cars have AWD... interesting.
                  @Adam +1
                  Audi A3
                    Why carry around the extra weight... it slows you down
                      Originally posted by she_dub View Post
                      Well done Andy
                      Thanks Bec... I think
                        Has anyone overseas converted the Rocco to AWD,,...I wonder
                          YUP!
                          HPA has done a twin turbo AWD version I believe.
                          I'm hoping VW make the next Scirocco R AWD, would have so much more potential!
                          No. 164 - HPA Competition Haldex Controller, KW V3's, Southbend Stage 2 Singlemass Flywheel, Simota Racing Air Intake
                            Beat me to it.......
                            HPA Motorsports Inc. Products: Scirocco
                            KMS Scirocco "Behind the scenes" - YouTube
                            But not quite what the question above really intended. Seem to remember there is a problem with the rear floor pan and fuel tank in relation to a standard AWD rear drive axle arrangement.
                            VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
                            Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
                              How close is the Scirocco R's power to the theoretical limit of power a FWD car can have before it's a bit useless (at least according to TopGear)?
                              Audi A3
