:: ECS Tuning :: VW 12V VR6 ECS Assembled Replacement Clutch Kits - Click Here !!!
  • :: ECS Tuning :: VW 12V VR6 ECS Assembled Replacement Clutch Kits - Click Here !!!
    If your VW 12V VR6 has a slipping clutch, worn flywheel, or poor gear engagement, instead of replacing one part at a time with an expensive OEM part, invest in one of several superb ECS-assembled Replacement Clutch Kits.
    The 18.5lb ECS Clutch Kit with steel flywheel includes the flywheel, pressure plate, clutch disc and all required installation hardware for a thorough clutch system rebuild.
    The more performance-minded enthusiast is catered to as well - the ECS-assembled 15.5lb Performance Clutch kit with single-mass flywheel improves throttle response and acceleration.
    http://www.ecstuning.com
