:: ECS Tuning :: VW B7 Passat LED License Plate Kit - Click Here !!!
  • :: ECS Tuning :: VW B7 Passat LED License Plate Kit - Click Here !!!
    VW B7 Passat LED License Plate Kit - $49.95!
    Ziza lighting is proud to introduce LED license plate bulbs for your Volkswagen that install in minutes. There is no need to wire up fancy resistors or rework your factory wiring to get them functioning properly.
    Simply remove your plate light assembly, and replace the factory incandescent bulb with our Ziza bulb. When installing bulbs, be sure to place the end with the large heat sink pointing upwards, this makes sure the brightest part of the LED will be shining down on your license plate.
    http://www.ecstuning.com
