:: ECS Tuning :: VW B6 Passat 2.0T K03 Turbocharger - Click Here !!!
  • :: ECS Tuning :: VW B6 Passat 2.0T K03 Turbocharger - Click Here !!!
    VW B6 Passat 2.0T K03 Turbocharger - Only $969.95!
    If you are looking for a replacement turbo to restore the power on your Passat 2.0T, this unit from Borg Warner will do the trick. This is a direct bolt-on replacement of your worn out or damaged factory turbo. A completely new, non-rebuilt unit that will spool dependably and restore lost performance.
    Be sure to order new banjo lines and crush washers to make your installation easier. It is suggested that lines are replaced to ensure proper oiling, as the old lines can lose pressure due to sludge.
    http://www.ecstuning.com
