:: ECS Tuning :: VW B3/B4 Passat VR6 Red Ignition Wire Set - In Stock !!!
  • :: ECS Tuning :: VW B3/B4 Passat VR6 Red Ignition Wire Set - In Stock !!!
    VW B3/B4 Passat VR6 Red Ignition Wire Set - Only $112.27!
    Heavily worn or damaged ignition wires place your engine at risk of cylinder misfire. When one or more cylinders misfire, power declines dramatically, and the safety of each engine component is instantly compromised.
    By replacing each spark plug wire in one servicing, the probability of this catastrophic consequence is significantly reduced.
    Karlyn has developed a Spark Plug Wire Set for your B3/B4 Passat VR6 that installs the same as the factory set, utilizing stock lengths for a clean engine bay.
    http://www.ecstuning.com
