:: ECS Tuning :: VW MKV GTI Upgraded Belly Pan Kit - Click Here !!!
  • :: ECS Tuning :: VW MKV GTI Upgraded Belly Pan Kit - Click Here !!!
    VW MKV GTI Upgraded Belly Pan Kit - Only $78.95!
    Originally designed for MKV R32's, this belly pan covers the entire underside of your engine whereas the factory belly pan stops halfway. The R32 belly pan helps to protect against inclement weather, water and road debris which can effect critical engine components without the protection of the belly pan, causing corrosion and problems down the road. Keep the bottom-side of your engine looking good and staying protected with a full under-engine-coverage R32 belly pan kit!
    http://www.ecstuning.com
