:: ECS Tuning :: VW B5 Passat 1.8T Valve Cover Gasket Sets - Click Here !!!
  • :: ECS Tuning :: VW B5 Passat 1.8T Valve Cover Gasket Sets - Click Here !!!
    VW B5 Passat 1.8T Valve Cover Gasket Sets - Starting At $14.95!
    If you're beginning to notice oil drips on the ground, a burning oil smell or smoke from underneath the hood, a leaking valve cover gasket or camshaft tensioner gasket may be the culprit. A common gasket to leak on VAG engines, the valve cover gasket is nothing to ignore. Don't forget to always replace the camshaft tensioner gasket at the same time as these are also prone to leaking. A small amount of RTV silicone is not included, but recommended in several transitional areas of the cylinder head valve cover rail.
    http://www.ecstuning.com
