VW MKV GTI ECS Billet Boost Tap - $39.95!
If you're planning on incorporating any vacuum-assisted accessories into your MKV GTI, you will need a reliable pressure reading from your engine. ECS engineers have again arrived at a simple, durable, and tasteful billet aluminum piece to suit your needs.
The ECS Boost Tap clips in between your PCV hose and intake manifold, giving you up to two inlets for your creative use. The kit includes all hardware and a set screw for blocking off the unused inlet when only one vacuum port is required for a particular application.
