VW B5 Passat 1.8T Oil Sludge Repair Kits - $154.95!
Do the internals on your engine look all sludged up? Take care of the most problem prone areas on the 1.8T engine with this custom kit.
Most cases of oil pressure problems come from an plugged oil pick-up tube which causes a drop in oil pressure. The recommended repair is replacing the oil pump with a new pick-up tube, followed by switching to a bigger capacity oil filter with synthetic oil.
This kit includes:
Oil Pump w/ Pick-up Tube & Screen
Oil Pan Gasket
Large Oil Filter
Pentosin High Performance II Engine Oil (5W-40)
Oil Drain Plug
Silicone Sealant
