VW MKIV Jetta Adjustable Sway Bar End Links - $129.95!
Adjustable sway bar end links allow you to lower your car without worrying about clearance issues between your sway bar and axles. As the car is lowered, the sway bar and axle geometry is changed slightly causing the sway bar to contact the axles at certain points of suspension travel.
Our stainless steel adjustable sway bar end links feature polyurethane bushings for optimal performance and long service life.
To view our video click - Here
