:: ECS Tuning :: VW MKIII Jetta 2.0L Front Wheel Bearing Kits - Click Here !!!
  • :: ECS Tuning :: VW MKIII Jetta 2.0L Front Wheel Bearing Kits - Click Here !!!
    VW MKIII Jetta 2.0L Front Wheel Bearing Kits - Starting At $29.95!
    Wheel bearings are one of the most crucial components of a car's suspension. Located in the wheel hub, brake drum, or rotor itself, the bearings support the full weight of the vehicle while allowing the wheels to rotate smoothly within a steel enclosure.
    Dysfunctional bearings are simply the result of the rigors of daily driving, and should be replaced at the first sign of failure.
    Worn bearing symptoms range from loud noise emanating from the wheel hubs to rough ride characteristics.
    ECS presents several bearing solutions as well as an invaluable installation kit.
    http://www.ecstuning.com
