ECS Tuning's MKIV R32 Exhaust Flapper Wiring Kit - $49.95!
The dim stock reverse lights might leave you guessing as to what lurks behind your car. Technology has improved, and ECS is on the forefront. The pinnacle of the Golf IV platform, your R32 represents uncompromising
performance engineering and design - make it sound like it.
The ECS MKIV Exhaust Flapper Wiring Kit gives you control of your Wookie's
VR6 growl on command from right inside the cabin, by opening or closing
your exhaust flapper valve.
Three valve positions can be selected via switch: closed to temper cabin decibels, or open for a noticeable bump in low-rpm HP. A third option will revert to factory performance.
To view our video click - Here
Install PDF can be found - Here
