ECS B5 Passat 1.8T Polyurethane Performance Snub Mount - $34.95
When the stock snub mount fails, the entire drivetrain can experience excessive movement, both torsionally and laterally. This movement ultimately results in a less refined and immediate feeling when you put the pedal to the metal.
ECS Tuning has designed its own polyurethane snub mount. A direct-fit mount with higher durometer and more robust construction. You'll immediately feel an improvement in throttle response, shift feel, and a more solid drivetrain.
If your B5 is wearing many miles or has power-adding mods, the ECS poly snub mount is your next logical upgrade.
For our install PDF please click - Here
