Stage 1 Rear Big Brake Kit - VW MKIV 337/20th/R32/GLI - $599.95
If you've pumped up the power under the hood of your MKIV, there's nothing like a little added deceleration to keep you out of the weeds.
Step up from stock cast iron 256mm rear rotors to 306mm, two-piece Tru-Float rotors. Durable and good looking, these ECS Tuning-engineered rotors combine lightweight anodized aluminum hats with vented, cross-drilled and slotted cast discs. Mount them easily, using the kit brackets and included hardware.
Add our Exact-Fit brake lines and brake pads of choice for an arresting rear brake upgrade that slows your car with authority... and style.
