Stage 1 Rear Big Brake Kit - VW Golf/Jetta/New Beetle - $499.95!
If you have power-adding modifications on your MKIV Golf/Jetta or New Beetle, the next upgrade is more stopping power.
The ECS Tuning 302mm two-piece Tru-Float rotors increase swept area and braking torque without weight penalty. Precision-machined caliper carrier brackets space out your stock brake calipers to match the new rotor, and ECS Exact-Fit brake lines provide pad-squeezing fluid pressure.
Designed as a compliment to your ECS Tuning Front Big Brake Kit, this Stage 1 direct-fit kit helps you keep your speed in check.
