Volkswagen MKII/MKIII Lightweight Adjustable Cam Gear -$99.95
Engine performance starts with breathing, and cam timing has a big effect on air flow at different rpm. Stock cam/sprocket timing delivers a boring compromise between smooth idle and reasonable performance. ZZZZZZZ.
Why not dial in a new power band that delivers torque where you want it, with this lightweight, adjustable cam gear.
Bolt it on in place of the stock sprocket, then use the built-in adjustment range to rotate the cam for improved low-end or top-end performance.
Quality materials. Built in calibration gauge. New low price.
Hat trick.
