:: ECS Tuning :: Volkswagen MKIV 6-Speed Clutch Bleeder Block - New Item !!!
  • :: ECS Tuning :: Volkswagen MKIV 6-Speed Clutch Bleeder Block - New Item !!!
    Volkswagen MKIV 6-Speed Clutch Bleeder Block - $59.95
    ECS proudly introduces our all new clutch bleeder blocks for VW 6-speed transmissions.
    This tough, durable upgrade has a larger internal fluid passage for increased flow and quicker clutch action. Its rigid, black anodized body resists pressure and heat, and is less likely to leak than the metal insert in the plastic-bodied factory original.
    Installation is child's play. Our complete kit comes with fresh fluid seals and retainer clips, and a bleeder screw with check valve to make bleeding a one-man job. Our free online pdf shows you how.
    http://www.ecstuning.com
