Hi all,
I am pretty new in this forum and in Car. I would like to ask everyone to share the suspension change experience. I am planning to get Suspension Spring change to be either VWR or H&R. I understand Coilover would be a much better option. However, the cost would be too much for me. In addition, Only the KW suspension support the Volkswagen DCC. However, it would be around 4000 AUD with installation.
If you can share your experience, that will be appreciated.
Thanks,
- VWR & H&R, Which one is better. (In terms of comfort, more compatible to the stock shock)
- Bolts and nuts need to replace? I have heard that the suspension and nuts are the high tension stretch bolts. Therefore it is only one off use. If the bolts and nuts need to replace, where would you guys order it?
- Will you install it from the Offical Volkswagen Dealer Service, or get the Volkwagen tuner to do it, like Volksmuller and Exoticars in sydney?
Thanks,
