Matching centre bore diameter? Mk5 GTI
for the 57.1 to 66.6 part you just need hubrings. can get from your local tyre/wheel shop sometimes or just on ebay (normally $20 for 4 abs plastic ones) just be sure they sit flush or recessed in the back of the wheel. I've had to trim a lot of hub rings for merc wheels becuase they have a tiny chamfer compared to most other wheels
they can be centred by just using wheel bolts but you will most likely have vibration.
if using merc wheels be sure to use the right length bolts (they usually require longer bolts) and the right bolt seat
Thanks Dilan...something like this I'm guessing:
Wheel HUB Centric Rings Spacer OD 66 6mm ID 57 1mm Aluminum Alloy | eBay
yep thats them.
just keep a eye on the chamfer. as I said, I had to shave some of mine down.
I find getting plastic/abs ones ideal so you can shave the back down to reduce the chamfer easier
Originally posted by An7on View PostG'Day All,
I've found a set of wheels I really like...
But the centre bore diameter is 66.6mm. With the Mk5 bore being 57.1mm will I need an adapter (if such thing exists)?
Or will they centre by way of the wheel nuts...Am I playing with fire?
[ATTACH=CONFIG]16664[/ATTACH]
What size & ET are the wheels as Mercedes rims often have too much poke
Local $23
plastic - $19 - ex-UK
Alloy Wheel HUB Centric Spigot Rings 66 6 57 1 Wheel Spacer SET OF 4 | eBay
alloy - $14 - ex-hong kong
4pcs Aluminum Hubrings 57 1mm CAR HUB TO 66 6mm Wheel Bore FOR CAR Auto | eBay
edit: I really should read the other posts before replying....carandimage The place where Off-Topic is On-Topic
Originally posted by An7on View PostThanks for the heads up Juzzpc. Were they 35 or 45 offset?
I was planning on getting the 45 offset to avoid the "poke".
