front and rear swaybars on a mk1 golf
  • front and rear swaybars on a mk1 golf
    hi all
    Im new to the forum and was wondering, if i put a front and rear swaybar on a mk1 golf will it pick up either of the rear wheels when i go around a corner? because i heard that it will pick up the out side rear wheel when i go round a corner.
    thanks in advance
    Tim
    Depends on a lot of things like tyres, how fast you're going, the camber of the road etc etc, but yes it is possible.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      Mate u can pick up the inside rear wheel if the its nice n stiff... Also yes u can corner real hard and pick up the outside wheel...
      28mm rear bar but u also gota have suspension to suit...
      Dad on picking up the inside wheel coming into Dandenong Rd (Sandown)
        well i have a 25mm front swaybar but i was thinking of buying a whiteline swaybar for the rear. i also have adjustable konis all round so i dont if that would make any difference.
          Yeah no probs... Get a 28mm one on the rear... Nuespeed, autotech, whiteline etc are all good...
            thanks
            thanks for your help guys and i shall get a bar for the rear
              bars..
              Use to pick up the inside rear on my rocco ( A1 chassis) with factory GTI sway bars when doing track play years ago.. all without much effort.
              Lots of MK 1 Scirocco's...
              Cheers,
              Grant...
