need wheel experts help!
  • need wheel experts help!
    hey guys I got some bbs rm 15x6.5 et15 and plan on running 195/50 on my 1998 6n polo! so I thought id test fit them today and im not sure if its right or im being weird, so please help!?
    Lip sits outside the bodywork = illegal fitment.
      anyway to make it fit inside the bodywork?
        You'll likely need new wheels to get proper fitment. These have too aggressive offset to be legal on your car (unless you're just fitting for shows).
        You could take them to a good wheel/machine shop to see if you can get them machined to reduce the offset. Depending on how much material there is it may be possible.
        Otherwise you'll have to find what car these suit and offload them.
        - Tigger73's 125TSI Build
          Do what the 4wd boys do, fit spats, you can trim them so they fit correctly and your wheel should be legal.
          Done all the time
            Spats?
                Oh ok! Now I'm with ya, but that's a lot of work for wheels
                  Sh*t as if ET15 6.5 is poking! I really doubted this. Are the backs of the wheels 100% against the hubs? If so how many mm of poke do you have? Could get smaller lips which would take you back another few mm - but that's probably not worth it. Guard rolling? There's a few different routes.
                  2019 132TSI Tiguan
                  2011 Audi S4 Wagon
                  1988 MK1 Caddy
                  2006 Polo GTI
                    Yeah the backs are 100% touching, not sure how much it is out by! Guessing about 2-3mm
                      If it's only that little I reckon you could:
                      a) get the backs shaved down at the same time as the drill and fill
                      b) pull your guards to cover that 2-3mm
                      c) run stretched tyres so you don't rub against the guards.
                      d) hope you don't get pulled by VIC Police.
                      e) all of the above.
                      2019 132TSI Tiguan
                      2011 Audi S4 Wagon
                      1988 MK1 Caddy
                      2006 Polo GTI
                        p.s. they do look absolutely amaze balls and will definitely be worth the effort you're putting in to them! I would've held on to them if I could've widened them out but imagine sticking another 25mm of poke on top of what you've got now - that's what I'd be dealing with haha!
                        2019 132TSI Tiguan
                        2011 Audi S4 Wagon
                        1988 MK1 Caddy
                        2006 Polo GTI
                          Yeah f-that lol yeah I really love them so got to figure something out
                            A wheel specialist should be able to machine the inner face of the wheel hub if there is sufficient metal to work with. It will depend how deep they have drilled the clearance holes for the wheel bolts.
                            I know a couple of places in Sydney that can do it. Vic should have a few too. Even a machine shop could do it but they might not know how much metal you need to stop the bolts from pulling through.
                            Angles on the photos don't really tell how bad it is
                              I'm going to a wheel specialist Saturday, so hopefully I can get it all worked out
