Hey guys i bought some bbs wheels and the centre bore is too small on them any idea how to fit them or where i can get them machined out? if not ill just sell them! cheers
Reboring rims
a location would be helpful.
Neale Wheels
Mullins
BSA
possibly Simmons
possibly OTR
Coastal?
Any machine shop should be able to do it as well
IIRC, when I was thinking about an 8mm slice off the hub on some BBS's it was about $35-$45 a wheel but they needed to see it to ascertain if there was enough metal on the hub to do it safely.carandimage The place where Off-Topic is On-Topic
yeah i called BSA and they said $35 a wheel so i think im going to head over there when i get some more money ahahOriginally posted by brad View PostNeale Wheels
Mullins
BSA
possibly Simmons
possibly OTR
Coastal?
im no good with wheels at all i know the offset is +55, 7" wide do you think they will fit?Originally posted by brad View PostWork out whether your offset is OK too - it won't be much more to get that sorted at the same time.
I'm going to assume you bought the BBS wheels as fitted to a subaru liberty B4. If that's the case then the offset will be high and depending on your type of mkiv then brake clearance may be an issue. Also, the wheels will sit quite a fair way in the wheel wells and look pretty sad.
There are other wheels worth your effort/time/money.
so you think i should just get rid of them?Originally posted by Bflat View PostI'm going to assume you bought the BBS wheels as fitted to a subaru liberty B4. If that's the case then the offset will be high and depending on your type of mkiv then brake clearance may be an issue. Also, the wheels will sit quite a fair way in the wheel wells and look pretty sad.
Depends on how much you paid for them and whether after the added expense of reboring they're still a good purchase. I recently had stud holes widened from 12mm (jap spec) to 14mm for $140. This was justifiable as the wheels were cheap when purchased and are still sellable for more than the investment.
If you don't plan on treating them as a commodity and genuinely like the design and how they fit then keep them.
Dunno. I only know MkV/VI fitments. Best to ask in the MKIV area or Wheels area. Work it all out first or it will be an expensive mistakecarandimage The place where Off-Topic is On-Topic
$500 for them with 80% tread all round so i think its a bargain if not i can just resell for more.Originally posted by Bflat View PostDepends on how much you paid for them and whether after the added expense of reboring they're still a good purchase. I recently had stud holes widened from 12mm (jap spec) to 14mm for $140. This was justifiable as the wheels were cheap when purchased and are still sellable for more than the investment.
