What is everyones suspension setups?
  • What is everyones suspension setups?
    After the last post I thought it might be good to get an idea of just what everyone is running, coilovers, pollybuses etc
    So though id start:
    My plan
    solid adj strut tops
    polly bushes throughout
    Koni or Kw coilovers
    25mm front arb
    28mm rear arb
    Planing for track days, fast road etc....
    ok I know this my plan a nd not my car at the mo, but its the sort of list im looking for!
    73 mini clubman supercharged money pit
    lowerd koni shocks
    lowerd springs cut (i know i know its bad)
    setup is only temporary ATM
    other than that the ride is perfect like standard and handles really well
    wabit
      My setup is:
      -KW Front Anti-Sway bar.
      -KW coilovers (V1's).
      -Neuspeed adjustable rear anti-sway bar.
      No complaints at all with this setup, the car is on rails and everyone who rides in the car comments on the surprising ride comfort.
      Snowy
        kings springs - extra superlows (cut 1 or 2 coils)
          Mines moderate I guess but it does the trick for me anyway:
          -KW V2s
          -New strut top mounts
          -Neuspeed Front Strut brace
          -Rear strut brace
          Also looking at picking up a rear sway bar as whoever I have talked to I have heard that the rear sway bar is one of the best suspension/handling mods you can do.
            My Mk5 GTI is stock as a rock at the minute. Still deciding which way to go.
            My mk3 VR6 has
            installed already
            PSS9 coilovers (in dire need of a rebuild)
            neuspeed rear swaybar
            on their way over or waiting in my garage to be installed
            WRD Lower stress bar
            HD upper strut mounts
            R32 control arm bushes
            front eibach strut brace
            FOLLOW US ON FACEBOOK
              my sportline is running...
              FK Koni Sport coilovers
              Front upper and lower strut brace
              Rear strut brace
              poly bushs and swaybars to follow
              Ps, the pic below is my old koni shock and springs!!!!
              Velly
              '91 2.0 8v GTI
              Originally posted by DubSteve
                Red MkI 5door 1979
                Front
                Kings springs 30mm lowered springs
                Gabriel Gas Ryder strut inserts.
                GTI sway bar
                SuperPro poly control arm bushes to be fitted.
                Std GLS solid discs and callipers.
                MKII GTI Steel wheels 14x6.
                195/60/14 Bridgestone G'grids
                Rear
                Gabriel Gas Ryder Struts.
                GTI sway bar
                Superpro poly Beam Axle Pivot Bushings to be fitted
                '97 Cordoba drum brakes.
                Cordoba Booster and 20.6mm master cylinder.
                White MkI 5door 1979
                Front
                Upper strut brace.
                Lower strut brace.
                Whiteline 24mm sway bar
                Std GTI vented discs and callipers.
                185/60/14 B.F.Goodrich g-force sports
                Rear
                Upper strut brace.
                GTI sway bar
                Toledo solid discs and callipers.
                MK III booster and 22mm master cylinder to be fitted.
                7? MK1 Caddy
                79 B1 Passat Dasher Project
                12 Amarok
                  KW V2 Coilovers
                  20mm front & rear sway bars (nfi on brand)
                  stock bushings
                  Fairy basic but I'm happy with the handling. Just wish I had some decent tires, nexen 3000's suck!!
                    Stock shocks
                    stock springs, chopped by 4"'
                      -KW V2s
                      -Whiteline Front and Rear adjustable sway bars
                      -ECS tuning dogbone mount (black poly)
                      -ECS tuning bushings all around
                      Sticks like $%!T to a babys bum!
                      Originally posted by Whubbsie
                        MKIV 2004 2slow Sport
                        H&R Sport Springs.
                        Front 1.4" Lower Rear 1.5" Lower
                        Stock Shocks
                        Handles good, no body roll.
                        I can feel the bumps more.
                        Will upgrade shocks when they wear out, looking at Koni's.
                          1998 Golf GL 2.slow
                          Eibach pro spring kit on standard shocks, 38mm drop all round.
                          Sits flat on the road i.e dual lane roundabouts at well over the speed limit and in the lines, and works well with my nice silverstone 205/45/16W tires.
                          I'm happy
                            h&r coilovers
                            h&r front and rear sway bars
                            uprated engine mounts and dogbone mount.
                            about to uprate suspension bushes.
                            sticks to the road like superglue!! and not bone jarring rough.
                              In car:
                              Koni Special (Red) shocks - front = half-turn from stiff, rears = 3/4 turn from stiff
                              Ground Control spring seat sleeves (height adjustment)
                              Ground Control/Eibach custom springs - front = 300 lb, rear = 250 lb
                              Have but not installed yet:
                              Front HD strut mounts
                              Rear polyurethane strut mounts
                              Eibach flat strut bar
                              VR6 control arms and ball joints
                              Present: Mk3 Golf variant.
