New rims but scrape on calipers....
  • New rims but scrape on calipers....
    just bought some custom rims from a great bloke, unfortuantly the rims will scrape on the calipers and i was wondering if there was any other way of clearing them, (only the front), without using spacers obviously, at the moment they have very little clearance like 2mm, but if i need to change the pads they will definetly scrape.... :'( any solutions????
    On his GTi he had no clearance, mines a mk5 FSI pretty stock
    P.s. new dubber
    What sort of wheels are we talking about?
    Have seen guys taking a mm or two of material off the caliper, but its not something you just want to muck around with
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      Obviously the wrong offset or the wrong rim diameter . You do realise spacers are illegal on the road.
      Perhaps not a good buy.
        OP, you say they scrape in one sentence and then there's 2mm clearance mentioned in another? Will the wheel rotate when bolted up or not?
          it does currently clear with the current pads, but probably not with new ones.
          also the guy says i can take them back if i wish, whats reccomended??
          btw im not gonna use spacers no matter what
            Take them back and buy some with proper offset etc They are obviously not the correct ones for that car.
            Grinding calipers may come back to bite you if anything breaks
              ok will do thanks for the awesome feedback, ill arrange for that to happen, thanks guys
              rookie error haha
                Offset isnt the factor that decides if a wheel will clear or not, its the design of the wheel
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  But wrong offset for that design
                  Why not get a new set of pads (you'll need them sometime) and confirm the clearance (or lack, thereof) before returning the rims?
                  Resident grumpy old fart
                    Yep exactly
                    Bora gone
                    Vento VR6
                    MKIV GSW TDI
                    7P Touareg TDI
