Vic/Melbourne/SE Wheel Alignment with subframe shift
  • Vic/Melbourne/SE Wheel Alignment with subframe shift
    Since many late model VWs have very limited front end adjustment (pretty much only toe adjustment) but also have slack built into the subframe mounts (though oversized bolt holes), the only way to get a perfect alignment is to loosen off the subframe mounts and shift the subframe so that camber and castor are equal.
    Does anyone know of anywhere in Melbourne (preferably SE) where they will do this as part of a wheel alignment?
    The place I used last time knew nothing about this
    Resident grumpy old fart
    Try Traction Tyre Centre in Rowville Traction Tyre & Suspension Centre - Yokohama Motorsport Distributor
    Trutrack Suspension are really good too but not SE Melb Trutrack Car Suspension Melbourne | Car Suspension | Melbourne Dynamic Wheel Balancing
    There is another in Moorabbin but their name escapes me..
