hey i own a 2011 mk5 jetta and i wanted to put on some 17 inch fat bbs rims on it but have no idea what my wheel offset and stud pattern is ? ( i was told it was 5 x 112 i think ) or any suggestions on what rims would suit my car ?
Need help with wheel details for my mk5 jetta
Mk5 Jetta will be 5x112 and the Offset will be stamped on the inside of your wheel e.g. ET51
A combination of offset, wheel width, bolt pattern and centrebore are required to get a correct fitting wheel.
Yes it would be on the stock wheels.
That way you can use a wheel size calculator to work out what size you can upgrade to while still keeping it legal.
This^^Originally posted by team_v View PostYes it would be on the stock wheels.
5x112 and 57.1 for the centre bore wont be stamped on the wheels.
but the width and the offset of your current set up will be. as said above, use that to work out what you want
Use this best size comparator I know of
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Use internet explorer page doesnt like Firefox2021 Kamiq LE 110 , Moon White, BV cameras F & B
