N27 - Nitrogen vs Compressed Air in Tyres
  • #31
    Originally posted by brad View Post
    I worked at QF Engineering for 17 year. Hands-on in the components area & then planning for sheet metal, undercarriage, machine shop, interiors, evacuation systems, prop shop & other stuff, so I was never directly involved in the wheel shop.
    From observation:
    Widebody rims are in 2 halves with an o-ring seal. The o-ring gets a light coating of oil/lube but everything else is wiped clean with alcohol.
    The tire is dropped on the rim-half, o-ring fitted & the other rim-half fitted & bolted/torqued. Tire assembly is placed in a cage, then they simply try & inflate the tire. If it won't seat with normal pressure then i think they used talc to lubricate the bead.
    They did have some type of purging process but I never looked very closely (usually walking to the canteen). They used to let them sit for a few days as well & would periodically check the pressure.
    Sorry i can't be more helpful but it wasn't my area. Ask me about bench testing an RR RB211 Variable Inlet Guide Vane controller & I can make a bit more sense (not much though).
    Good one Brad ... thanks for the post. Yep, of course ... no need to use water or water/detergent when there's either rubber lube or talc.
    RB 211's? BIG!
    sigpic2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
