Stud pattern shared with Nissan?
  • Stud pattern shared with Nissan?
    Hey all, long shot yes but I just picked up a new mk1 golf and I have the opportunity to pick up some demons wheels I used ton Which will be comming off an r31 skyline. I don't have the wheels here to check but is theirany smart cookies who can tell me if they share patterns (vw to nissan) and what my chances are of them fitting?
    Sorry, phone spell check: demons= Renoma
      The mk1 will be 4 x 100. The R31 5 x 114.3
      Use ECS or adaptec speedware to source adapters. Much easier if the wheels are higher offset (the ET number closer to 50 than 0 for example) to give you space to use the adapters (obviously going to push the wheel face outward towards the guards (or past it))
        31s are 4 stud, or am I reading that wrong
          R31 Skylines are 4 x 114.3, and as stated above, Mk 1 Golfs are 4 x 100....
            They would look hot on my yellow MK1 if I could somehow make it work. Will try to find out the ofset
              Fat fingers yeah 4x114.3 on the R31
                how much would adaptors set me back do ya think?
                  dapters are around 400-450 landed from the US.
                  another possibility is to have the wheels filled and drilled. can be expensive depending where you get it done, but i think you'll find R31's have low offset wheels, which means adapters are out of the question.
                    dont ask me how i didnt know this but the wheels are actually "SSR Renoma Paris" wheels, never knew they were SSR
                    carry on
                      As Jarred said, what's the ET of the wheels?
                        im pretty sure theyre @et15 and they weigh in around 6.5 wide so theyll work well with a set of 165/50x15s and adaptors
