BBS Wheel Help
  • BBS Wheel Help
    Hi Everyone
    Just got my LM's and want to get them re-polished, does anyone know what bolt removal tool i need
    This place sells some, prices are not too bad
    Racing Team Hofmann RTH items - Get great deals on BBS Felgen, RS RM items on eBay.co.uk Shops!
    MODS- TOO MANY
    They are just multipoint sockets usually. Rs's are 8 and 9 mm from memory. ( nut side bigger )
    Originally posted by Preen59
      I think Alex is right there. The normal 12 (?) point socket should be fine for the front, and regular hex socket for the rear. Don't ask me what sizes though.
      I freaked out when I had my works, I thought I needed a special tool too. Then I grabbed my socket set and thought, "oh wait a minute..."
        Just tried one of the H&R 15mm spacers in the back of one and the center bore is too small, just by a little
        Doh
        MODS- TOO MANY
          Cb of the wheel or the spacer?? If the spacer is big I can machine it to suit if it small you just need a spigot ring.
            I think it might be the spacer, they are made to fit OEM wheels
            Just tried them on, it is the wheel that dont fit, but seeing as i am going to use spacers, is it easier to machine the spacer than the wheel
            MODS- TOO MANY
              From what i can see online the VW has a 57mm bore and the WRX a 56.1 ?
              They are a 48 offset so wrx fitment
              MODS- TOO MANY
                I believe so troy
                Could get the wheels done, that way they'd be VW fitment, and fit on any VW spacer etc...
                  Just went to Eastern Wheel Works
                  They can make the 2 piece LM's to 3 piece, hmmm 8.5 or 9 inch rear ?
                  MODS- TOO MANY
                    go 9's you sook 8.5" gets swallowed up at the front too with the right offset
                      They are a +48 offset, so guess they come in closer to the strut, I cant get them on untill i get the center bore machined
                      Guessing if there were a +35 I wouldnt be able to go as wide, so i am lucky
                      MODS- TOO MANY
                        Guess i will need a wider tyre on the back, so it dosen't look funny.
                        At the moment they are 205/40 all round, maybe backs need to be 215/40
                        MODS- TOO MANY
                          I dont want them to stick out, i dont know if I can get 9's to sit flush. Once the center bore is done, they will put it on the hoist and have a look at what I can get under there
                          Guess by the time they are finished, widened, polished, powder coated they are going to cost $$$$
                          As Tim says, "you have to pay to play"
                          And josh they wont be Gold, or White lol
                          MODS- TOO MANY
